[osgeo4w-dev] Problems with QGIS
Müller, Andreas, Dr. phil. muellea at uni-trier.de
Mon Sep 4 02:29:26 PDT 2023
I've never seen this error before, but I suspect your DB file may be broken. I/O errors could also indicate a corrupt file system (on your hard drive), so you should check that first (right-click your drive in Windows Explorer and select Properties, then Tools).
To determine if the qgis.db file is corrupt, you can check this file as well. It's a SQLite database and contains tables for storing QGIS properties. Unfortunately, AFAIK Windows doesn't have a standard tool to open the SQLite file. But there are possibilities: 1. QGIS can open the db file, 2. there is a command line tool for qgis, sqlite3.exe, which can be used via the OSGeo4W shell, or you can install a third-party tool, e.g. the DB Browser for SQLite. By the way, the location is either: ".\osgeo4w\apps\qgis-ltr\resources" or ".\AppData\Roaming\QGIS\QGIS3\profiles\default". If the file cannot be opened with these tools, it is probably corrupt.
Maybe someone else knows how to replace qgis.db?
Dr. Andreas Müller - Universität Trier - FB VI
Geoinformatics – Spatial Data Science,
54296 Trier, Behringstr. 15, ++496512014576
________________________________________
Von: osgeo4w-dev <osgeo4w-dev-bounces at lists.osgeo.org> im Auftrag von Juan Rafael Suárez <juanrsuarez267 at gmail.com>
Gesendet: Sonntag, 3. September 2023 00:42:23
An: osgeo4w-dev at lists.osgeo.org
Betreff: [osgeo4w-dev] Problems with QGIS
I am working in windows 10.0 64.0 bits
I upgraded to Qgis 3.28.10
Now I have these issues:
When I start the program at the first time nothing happens.
Then I start by the second time, and the the program starts, but I get this message:
"Creation of missing tbl_srs in the private qgis.db failed
disl I/O error"
I click on the OK button and then the program starts.
I can work on qgis, but in the moment I select any vector layer, and I try to go to the properties form, the program crashes, doesnot work any longer.
Then when I try to close the program I receive this message:
"qgis-ltr-bin.exe is not responding"
I dont know what is the problem.
If somebody knows and may help me I will appreciate so much.
Best regards.
More information about the osgeo4w-dev mailing list
