[osgeo4w-dev] Problems with QGIS
Müller, Andreas, Dr. phil. muellea at uni-trier.de
Mon Sep 4 03:07:54 PDT 2023
Moin Jürgen,
In my experience some users have problems with command line tools or even never opened the cmd shell.
By the way, the "qgis.db" in the "privat" profile directory can deleted without issues, if it is broken. QGIS will create a new one on startup.
Dr. Andreas Müller - Universität Trier - FB VI
Geoinformatics – Spatial Data Science,
54296 Trier, Behringstr. 15, ++496512014576
________________________________________
Von: osgeo4w-dev <osgeo4w-dev-bounces at lists.osgeo.org> im Auftrag von Jürgen E. Fischer <jef at norbit.de>
Gesendet: Montag, 4. September 2023 11:55:24
An: osgeo4w-dev at lists.osgeo.org
Betreff: Re: [osgeo4w-dev] Problems with QGIS
Moin Andreas,
On Mon, 04. Sep 2023 at 11:52:38 +0200, Jürgen E. Fischer wrote:
> On Mon, 04. Sep 2023 at 09:29:26 +0000, Müller, Andreas, Dr. phil. wrote:
> > Unfortunately, AFAIK Windows doesn't have a standard tool to open the
> > SQLite file.
> sqlite3 contains sqlite3.exe
Oh, sorry - you mentioned that already - although to me that is the standard
tool.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                 IRC: jef on Libera|OFTC
More information about the osgeo4w-dev mailing list
