[osgeo4w-dev] A load of updates in OSGeo4W
Jürgen E. Fischer jef at norbit.de
Sun Apr 14 16:02:46 PDT 2024
Hi there,
I just uploaded an update to OSGeo4W.   It is basically a rebuild of everything
with a newer compiler (Visual C++ 2022) and updates of almost all versions.
The update should work cleanly and cause no visual changes.
The main change is the move from Python 3.9.18 to 3.12.3.  But there's also an
update to Qt 5.15.13, OpenSSL 3.   Qt6 was also added enabling an experimental
build of QGIS master with Qt6. Based on that there is also an experimental
version of QField.
GDAL and PROJ also were updated to the latest version.
The legacy GRASS 7 was removed because it doesn't support Python 3.12.  GRASS 8
was already available and QGIS switch to it long before this update.
Please test and report.
Jürgen
More details in the commit message:
A load of updates (fixes #788, #810, #816, #819, #820, #823, closes jef-n/OSGeo4W#21, refs qgis/QGIS#54491, qgis/QGIS#56499)
Highlights:
  Switched to Visual Studio 2022
  Qt6 6.6.3, PyQt6 6.6.1
  Qt5 5.15.13, PyQt5 5.15.10
  Python 3.12.3
  OpenSSL 3.0.13
  PROJ 9.4.0
  GDAL 3.8.5
  qgis-qt6-dev based on Qt6 next to qgis-dev based on Qt5
  experimental QField based on Qt6 / qgis-qt6-dev
Details:
  Removed:
    libjpeg (already replaced with libjpeg-turbo earlier)
    python3-clcache (replaced by ccache)
    python3-pyuv (dependency of python3-clcache)
  Updated:
    apache 2.4.52 -> 2.4.58
    arrow-cpp 7.0.0 -> 15.0.2
    boost 1.74.0 -> 1.84.0
    brotli 1.0.9 -> 1.1.0
    curl 8.4.0 -> 8.6.0
    draco 1.5.6 -> 1.5.7
    exiv2 0.27.3 -> 0.28.2
    expat 2.2.10 -> 2.6.2
    ffmpeg 5.1 -> 6.1.1
    freetype 2.10.2 -> 2.13.2
    gdal 3.8.4 -> 3.8.5
    gpsbabel 1.8.0 -> 1.9.0
    grass 7.8.8 -> 8.3.2
    grass8 8.3.2 -> 99 (transitional; depends on grass)
    gsl 2.6 -> 2.7.1+
    hdf4 4.2.16 -> 4.3.0
    hdf5 1.14.0 -> 1.14.3
    kealib 1.4.14 -> 1.5.3
    lerc 3.0 -> 4.0.0
    libharu 2.3.0 -> 2.4.4
    libiconv 1.16 -> 1.17
    libjpeg-turbo 2.0.7-esr -> 3.0.2
    libjxl 0.8.1 -> 0.10.2
    libmysql 8.0.21 -> 8.2.0
    libosmium-devel 2.18.0 -> 2.20.0
    libpng 1.6.37 -> 1.6.43
    libtiff 4.5.1 -> 4.6.0
    libxml2 2.9.10 -> 2.12.5
    libxslt 1.1.34 -> 1.1.39
    libzip 1.7.3 -> 1.10.1
    lua 5.4.4 -> 5.4.6
    lz4 1.9.3 -> 1.9.4
    minizip-ng-devel 3.0.2 -> 4.0.4
    node 16.14.0 -> 20.11.1
    oci 19.11 -> 21.13
    ogdi 4.1.0 -> 4.1.1
    opencl 2.0.10 -> 2023.12.14
    openfyba-devel 20150103 -> 20240408
    openjpeg 2.4.0 -> 2.5.2
    openssl 1.1.1w -> 3.0.13
    osm2pgsql 1.8.1 -> 1.11.0
    osmium 1.15.0 -> 1.16.0
    pdal 2.6.0 -> 2.6.3
    poppler 23.07.0 -> 24.04.0
    proj 9.3.1 -> 9.4.0
    proj-data 1.16 -> 1.17
    python3 3.9.18 -> 3.12.3
    protobuf-devel 3.13.0 -> 25.3
    qca 2.3.1 -> 2.3.8
    qscintilla 2.13.4 -> 2.14.1
    qt5 5.15.3 -> 5.15.13
    qtkeychain 0.13.2 -> 0.14.2
    qwc2 20220311-671a6e7 -> 20240408-3d95409
    qwt 6.1.6 -> 6.2.0
    saga 7.8.2 -> 9.3.1
    saga9 9.2.0 -> 99 (transitional; depends on saga)
    snappy-devel 1.1.9 -> 1.1.10
    spdlog-devel 1.10.0 -> 1.13.0
    sqlite3 3.41.1 -> 3.45.1
    swig 4.0.2 -> 4.2.1
    thrift 0.16.0 -> 0.20.0
    transifex-cli 1.6.5 -> 1.6.10
    utf8proc 2.7.0 -> 2.9.0
    wxwidgets 3.2.1 -> 3.2.4
    xerces-c 3.2.3 -> 3.2.5
    xz 5.2.5 -> 5.4.5
    yarnpkg 1.22.17 -> 1.22.21
    zlib 1.2.12 -> 1.3.1
    zstd 1.4.5 -> 1.5.5
  Updated Python extensions:
    python3-access 1.1.1 -> 1.1.9
    python3-affine 2.3.0 -> 2.4.0
    python3-alabaster 0.7.12 -> 0.7.16
    python3-argon2-cffi 20.1.0 -> 23.1.0
    python3-atomicwrites 1.4.0 -> 1.4.1
    python3-attrdict 2.0.1 -> python3-attrdict3 2.0.2
    python3-attrs 20.2.0 -> 23.2.0
    python3-autopep8 2.0.1 -> 2.1.0
    python3-babel 2.8.0 -> 2.14.0
    python3-backports.entry-points-selectable 1.1.0 -> 1.3.0
    python3-beautifulsoup4 4.9.3 -> 4.12.3
    python3-bleach 3.2.1 -> 6.1.0
    python3-certifi 2020.6.20 -> 2024.2.2
    python3-cffi 1.14.3 -> 1.16.0
    python3-cftime 1.2.1 -> 1.6.3
    python3-chardet 3.0.4 -> 5.2.0
    python3-click 7.1.2 -> 8.1.7
    python3-cligj 0.7.0 -> 0.7.2
    python3-colorama 0.4.4 -> 0.4.6
    python3-coverage 5.3 -> 7.4.4
    python3-cycler 0.10.0 -> 0.12.1
    python3-decorator 4.4.2 -> 5.1.1
    python3-defusedxml 0.6.0 -> 0.7.1
    python3-distlib 0.3.2 -> 0.3.8
    python3-docutils 0.16 -> 0.20.1
    python3-entrypoints 0.3 -> 0.4
    python3-esda 2.3.1 -> 2.5.1
    python3-exifread 2.3.2 -> 3.0.0
    python3-filelock 3.0.12 -> 3.13.3
    python3-fiona 1.9.5 -> 1.9.6
    python3-fonttools 4.28.5 -> 4.51.0
    python3-future 0.18.2 -> 1.0.0
    python3-gdal 3.8.4 -> 3.8.5
    python3-geoalchemy2 0.12.5 -> 0.14.7
    python3-geographiclib 1.50 -> 2.0
    python3-geopandas 0.14.1 -> 0.14.3
    python3-giddy 2.3.3 -> 2.3.5
    python3-greenlet 1.1.1 -> 3.0.3
    python3-h5py 3.8.0 -> 3.10.0
    python3-httplib2 0.18.1 -> 0.22.0
    python3-idna 2.10 -> 3.6
    python3-imagesize 1.2.0 -> 1.4.1
    python3-importlib-metadata 2.0.0 -> 7.1.0
    python3-inequality 1.0.0 -> 1.0.1
    python3-iniconfig 1.1.1 -> 2.0.0
    python3-ipykernel 5.3.4 -> 6.29.4
    python3-ipython 7.18.1 -> 8.23.0
    python3-ipywidgets 7.5.1 -> 8.1.2
    python3-isort 5.12.0 -> 5.13.2
    python3-jedi 0.17.2 -> 0.19.1
    python3-jinja2 3.1.2 -> 3.1.3
    python3-joblib 0.17.0 -> 1.3.2
    python3-jsonschema 3.2.0 -> 4.21.1
    python3-jupyter-client 6.1.7 -> 8.6.1
    python3-jupyter-console 6.2.0 -> 6.6.3
    python3-jupyter-core 4.6.3 -> 5.7.2
    python3-jupyterlab-pygments 0.1.2 -> 0.3.0
    python3-kiwisolver 1.2.0 -> 1.4.5
    python3-libpysal 4.3.0 -> 4.10
    python3-llvmlite 0.34.0 -> 0.42.0
    python3-lxml 4.6.2 -> 5.2.1
    python3-mapclassify 2.3.0 -> 2.6.1
    python3-markupsafe 1.1.1 -> 2.1.5
    python3-matplotlib 3.5.1 -> 3.8.4
    python3-mgwr 2.1.2 -> 2.2.1
    python3-mistune 0.8.4 -> 3.0.2
    python3-mock 4.0.2 -> 5.1.0
    python3-mod-wsgi 4.9.0 -> 5.0.0
    python3-mpmath 1.1.0 -> 1.3.0
    python3-munch 2.5.0 -> 4.0.0
    python3-nbclient 0.5.1 -> 0.10.0
    python3-nbconvert 6.0.7 -> 7.16.3
    python3-nbformat 5.0.8 -> 5.10.4
    python3-nest-asyncio 1.4.2 -> 1.6.0
    python3-netcdf4 1.6.3 -> 1.6.5
    python3-networkx 2.5 -> 3.3
    python3-nltk 3.5 -> 3.8.1
    python3-nose2 0.9.2 -> 0.14.1
    python3-notebook 6.1.4 -> 7.1.2
    python3-numba 0.51.2 -> 0.59.0
    python3-numpy 1.24.1 -> 1.26.4
    python3-openpyxl 3.0.9 -> 3.1.2
    python3-osmium 3.4.1 -> 3.7.0
    python3-owslib 0.29.2 -> 0.30.0
    python3-packaging 20.4 -> 24.0
    python3-pandas 2.0.2 -> 2.2.1
    python3-pandocfilters 1.4.3 -> 1.5.1
    python3-parso 0.8.0 -> 0.8.4
    python3-patsy 0.5.1 -> 0.5.6
    python3-pbr 5.5.1 -> 6.0.0
    python3-pdal-plugins 1.2.1 -> 1.3.0
    python3-pillow 10.0.1 -> 10.3.0
    python3-pirogue 1.2.5 -> 1.4.2
    python3-platformdirs 2.0.2 -> 4.2.0
    python3-plotly 4.12.0 -> 5.20.0
    python3-pluggy 0.13.1 -> 1.4.0
    python3-pointpats 2.2.0 -> 2.4.0
    python3-prometheus-client 0.8.0 -> 0.20.0
    python3-prompt-toolkit 3.0.8 -> 3.0.43
    python3-psycopg 3.1.9 -> 3.1.18
    python3-psycopg2-binary 2.9.3 -> 2.9.9
    python3-pum 0.9.12 -> 0.10.0
    python3-py 1.9.0 -> 1.11.0
    python3-pybind11 2.6.2 -> 2.12.0
    python3-pycparser 2.20 -> 2.22
    python3-pygments 2.7.2 -> 2.17.2
    python3-pymemcache 3.4.0 -> 4.0.0
    python3-pyodbc 4.0.30 -> 5.1.0
    python3-pyopengl 3.1.5 -> 3.1.7
    python3-pyparsing 2.4.7 -> 3.1.2
    python3-pyqt-builder 1.10.3 -> 1.16.0
    python3-pyqt5 5.15.4 -> 5.15.10
    python3-pyqt5-sip 12.8.1 -> 12.13.0
    python3-pyqtwebengine 5.15.5 -> 5.15.6
    python3-pyrsistent 0.17.3 -> 0.20.0
    python3-pysal 2.3.0 -> 24.1
    python3-pytest 6.1.2 -> 8.1.1
    python3-pytest-cov 2.10.1 -> 5.0.0
    python3-python-dateutil 2.8.1 -> 2.9.0.post0
    python3-pythonqwt 0.8.3 -> 0.12.1
    python3-pytz 2023.3 -> 2024.1
    python3-pywinpty 0.5.7 -> 2.0.13
    python3-pyyaml 5.3.1 -> 6.0.1
    python3-pyzmq 19.0.2 -> 25.1.2
    python3-qscintilla 2.13.4 -> 2.14.1
    python3-qtconsole 4.7.7 -> 5.5.1
    python3-qtpy 1.9.0 -> 2.4.1
    python3-quantecon 0.4.8 -> 0.7.2
    python3-rasterstats 0.15.0 -> 0.19.0
    python3-regex 2020.10.28 -> 2023.12.25
    python3-reportlab 4.0.4 -> 4.1.0
    python3-requests 2.24.0 -> 2.31.0
    python3-retrying 1.3.3 -> 1.3.4
    python3-rtree 0.9.4 -> 1.2.0
    python3-scikit-learn 0.23.2 -> 1.4.1.post1
    python3-scipy 1.10.1 -> 1.13.0
    python3-seaborn 0.11.0 -> 0.13.2
    python3-segregation 1.4.0 -> 2.5
    python3-send2trash 1.5.0 -> 1.8.3
    python3-setuptools 67.6.0 -> 69.2.0
    python3-shapely 2.0.2 -> 2.0.3
    python3-simplejson 3.17.2 -> 3.19.2
    python3-sip 6.1.1 -> 6.8.3
    python3-six 1.15.0 -> 1.16.0
    python3-snowballstemmer 2.0.0 -> 2.2.0
    python3-soupsieve 2.0.1 -> 2.5
    python3-spaghetti 1.5.3 -> 1.7.5.post1
    python3-spglm 1.0.8 -> 1.1.0
    python3-sphinx 3.3.0 -> 7.2.6
    python3-splot 1.1.3 -> 1.1.5.post1
    python3-spreg 1.1.2.post1 -> 1.4.2
    python3-sqlalchemy 1.4.42 -> 2.0.29
    python3-statsmodels 0.14.0 -> 0.14.1
    python3-sympy 1.6.2 -> 1.12
    python3-terminado 0.9.1 -> 0.18.1
    python3-testpath 0.4.4 -> 0.6.0
    python3-threadpoolctl 2.1.0 -> 3.4.0
    python3-tobler 0.4.0 -> 0.11.2
    python3-toml 0.10.1 -> 0.10.2
    python3-torch 2.2.1 -> 2.2.2
    python3-tornado 6.0.4 -> 6.4
    python3-tqdm 4.51.0 -> 4.66.2
    python3-traitlets 5.0.5 -> 5.14.2
    python3-typing-extensions 4.5.0 -> 4.11.0
    python3-tzdata 2023.3 -> 2024.1
    python3-urllib3 1.25.11 -> 2.2.1
    python3-virtualenv 20.5.0 -> 20.25.1
    python3-wcwidth 0.2.5 -> 0.2.13
    python3-wheel 0.35.1 -> 0.43.0
    python3-widgetsnbextension 3.5.1 -> 4.0.10
    python3-xlrd 1.2.0 -> 2.0.1
    python3-zipp 3.4.0 -> 3.18.1
  Just rebuilt with VS2022:
    api-ms-win-core-path-HACK 0.0.1
    avce00 2.0.0
    base 1.0.0
    bzip2-devel 1.0.8
    cairo 1.17.2
    entwine 3.0.0
    fcgi 2.4.2
    freexl 2.0.0
    geos 3.12.1
    gs 10.02.1
    icu 67.1
    imposm3 0.11.1
    laszip 3.4.3
    libgeotiff 1.7.1
    libkml-devel 1.3.0
    liblas 1.8.1
    libpq 16.2
    librttopo 1.1.0
    libspatialindex 1.9.3
    libspatialite 5.1.0
    libwebp 1.3.2
    mod_fcgid 2.3.10
    netcdf 4.9.2
    odbc-cpp-wrapper 1.1
    pcraster 4.4.1
    protozero-devel 1.7.1
    qgis 3.36.1
    qgis-ltr 3.34.5
    qtwebkit 5.212.0-alpha4
    qwc-services 1.3.4
    setup 1.1.2
    shell 99.0.0
    szip 2.1.1
    tiledb 2.8.2
    wingetopt-devel 1.00
  Repackaged/rebuilt for Python 3.12
    python3-async-generator 1.10
    python3-backcall 0.2.0
    python3-click-plugins 1.1.1
    python3-descartes 1.1.0
    python3-et-xmlfile 1.1.0
    python3-ipython-genutils 0.2.0
    python3-jupyter 1.0.0
    python3-mapproxy 2.0.2
    python3-mypy-extensions 1.0.0
    python3-pdal 3.2.3
    python3-pickleshare 0.7.5
    python3-pip 24.0
    python3-ply 3.11
    python3-pypdf2 3.0.1
    python3-pypiwin32 223
    python3-pyproj 3.6.1
    python3-pypubsub 3.3.0
    python3-pyserial 3.5
    python3-pytoml 0.1.21
    python3-pywin32 306
    python3-rasterio 1.3.9
    python3-remotior-sensus 0.3.5
    python3-snuggs 1.4.7
    python3-spint 1.0.7
    python3-spvcm 0.3.0
    python3-tomli 2.0.1
    python3-webencodings 0.5.1
    python3-wxpython 4.2.1
    python3-xlwt 1.3.0
  Added:
    grass7 99 (transitional; depends on grass(8); grass 7 doesn't support python 3.12)
    podofo 0.10.3
    qca-qt6 2.3.8
    qgis-qt6-dev (master based on Qt6)
    qscintilla-qt6 2.14.1
    qt6 6.6.3
    qtkeychain-qt6 0.14.2
    qwt-qt6 6.2.0
    uriparser-devel 0.9.7
    saga7 7.9.1 (old saga, just in case)
    qfield-dev 3.2.2 (experimental; depends on very heady qgis-qt6-dev; TODO split the latter to minimize qfield dependencies)
    poly2tri-devel 20240411 (qfield dependency)
    zxing-cpp-devel 2.2.1 (qfield dependency)
  Added python extensions:
    python3-anyio 4.3.0
    python3-argon2-cffi-bindings 21.2.0
    python3-asttokens 2.4.1
    python3-async-lru 2.0.4
    python3-charset-normalizer 3.3.2
    python3-comm 0.2.2
    python3-contourpy 1.2.1
    python3-debugpy 1.8.1
    python3-deprecation 2.1.0
    python3-duckdb 0.10.1
    python3-executing 2.0.1
    python3-fastjsonschema 2.19.1
    python3-fsspec 2024.3.1
    python3-h11 0.14.0
    python3-httpcore 1.0.5
    python3-httpx 0.27.0
    python3-json5 0.9.24
    python3-jsonschema-specifications 2023.12.1
    python3-jupyter-events 0.10.0
    python3-jupyter-lsp 2.2.5
    python3-jupyter-server 2.13.0
    python3-jupyter-server-terminals 0.5.3
    python3-jupyterlab 4.1.5
    python3-jupyterlab-server 2.26.0
    python3-jupyterlab-widgets 3.0.10
    python3-matplotlib-inline 0.1.6
    python3-maturin 1.5.1
    python3-momepy 0.7.0
    python3-notebook-shim 0.2.4
    python3-overrides 7.7.0
    python3-pathspec 0.12.1
    python3-psutil 5.9.8
    python3-psycopg2 2.9.9
    python3-pulp 2.8.0
    python3-pure-eval 0.2.2
    python3-pyarrow 15.0.2
    python3-pycodestyle 2.11.1
    python3-pyqt6 6.6.1
    python3-pyqt6-qscintilla 2.14.1
    python3-pyqt6-sip 13.6.0
    python3-python-json-logger 2.0.7
    python3-referencing 0.34.0
    python3-rfc3339-validator 0.1.4
    python3-rfc3986-validator 0.1.1
    python3-rpds-py 0.18.0
    python3-sniffio 1.3.1
    python3-sphinxcontrib-applehelp 1.0.8
    python3-sphinxcontrib-devhelp 1.0.6
    python3-sphinxcontrib-htmlhelp 2.0.5
    python3-sphinxcontrib-jsmath 1.0.1
    python3-sphinxcontrib-qthelp 1.0.7
    python3-sphinxcontrib-serializinghtml 1.1.10
    python3-spopt 0.6.0
    python3-stack-data 0.6.3
    python3-tenacity 8.2.3
    python3-tinycss2 1.2.1
    python3-websocket-client 1.7.0
Other changes:
* acceptable licenses updated
* switch to VS2022
* add bootstrap.cmd to
 * invoke installation of cygwin base,
 * clone the repo
 * build everything
* build process installs necessary tools if necessary
 * vs2022
 * debug tools (for dbghelp.dll)
 * cmake
 * ninja
 * ccache (supports msvc now)
 * enables long paths on build (for Qt6 / webengine / chromium)
* cleanups
* PACKAGES added to package.sh to list produced packages
* devenv replaced with msbuild
* Update of ECWJP2SDKSetup_5.5.0.2268-Update4-Windows.zip not automatically
  downloadable anymore (place in src/gdal/osgeo4w/gdaldeps and
  src/gdal-dev/osgeo4w/gdaldeps)
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                 IRC: jef on Libera|OFTC
Desc: not available
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20240415/def72944/attachment.sig>
More information about the osgeo4w-dev mailing list
