[osgeo4w-dev] [osgeo4w] #828: Postinstall script errors installing qgis-full 3.36.1-2 and qgis-ltr-full 3.34.5-2
OSGeo4W trac_osgeo4w at osgeo.org
Tue Apr 16 21:43:21 PDT 2024
3.34.5-2
Reporter:  andreaerdna  |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  new
Priority:  normal       |   Component:  Installer
 Version:               |  Resolution:
Keywords:               |
Comment (by andreaerdna):
 After removing dbghelp.dll from apps\qgis\ and rerunning etc\postinstall
 \qgis-common.bat, then crssync runs without throwing the error as it then
 probably uses the dbghelp.dll available in the system (version
 10.0.18362.1 in C:\WINDOWS\System32).
 Side note: I suggest to remove {{{@echo off}}} from etc\ini\qt5.bat,
 otherwise the commands after
 {{{call "%OSGEO4W_ROOT%\bin\o4w_env.bat"}}} in etc\postinstall\qgis-
 common.bat and other batch files are not displayed in the console and not
 saved in the log.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/828#comment:7>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
