[osgeo4w-dev] [osgeo4w] #821: Installation via OSGEO4W error: Could not load qgis_app.dll
OSGeo4W trac_osgeo4w at osgeo.org
Wed Mar 13 09:41:04 PDT 2024
Reporter:  cdragoste  |       Owner:  osgeo4w-dev@…
    Type:  defect     |      Status:  closed
Priority:  normal     |   Component:  Package
 Version:             |  Resolution:  invalid
Keywords:             |
Changes (by jef):
 * status:  new => closed
 * resolution:   => invalid
Comment:
 Sorry, misread the ticket:
 Easy downgrades are only possible if the dependencies didn't meanwhile
 change.  Otherwise you also need to downgrade dependencies to the version
 used for the earlier version.  Dependencies are not versioned, so that
 cannot be done automatically.  To make it even harder the required older
 versions might even not be installable anymore as only the current and the
 previous (and maybe a test version) are referenced.
 But you can try snapshots. See
 https://trac.osgeo.org/osgeo4w/wiki#Olderversionsfromreposnapshots
 Lacking a better option, resolving this as "invalid".
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/821#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
