[Osgeo4w-trac] Re: [osgeo4w] #5: setup crashes in win64,
windows server 2003
trac_osgeo4w at osgeo.org
Tue Jun 3 13:35:44 EDT 2008
#5: setup crashes in win64, windows server 2003
Reporter: jmckenna | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: Beta Release
Component: Installer | Version: Alpha
Resolution: | Keywords:
Comment (by jmckenna):
"In r1027, r1028 and r1029 I have added a hacky "--safe" mode that skips a
bunch of win32 calls related to administrative capabilities. This safe
mode can be turned on with the --safe commandline switch to setup. I would
consider making this the default, but I don't really understand what the
code I'm disabling does.
The changes can be seen at:
http://trac.osgeo.org/osgeo/changeset?new=osgeo4w%2Fsetup%401029&old=osgeo4w%2Fsetup%401026
Tamas, I'm uploading a new osgeo4w-setup.exe. I'd appreciate it if you
could test it sometime on win64 (passing the --safe switch) and see if it
works.
My debugging conditions on my test win2003 server were very painful
(remote desktop over a very high latency link) so I did not try and do a
good job of debugging, just hack around the problem code. Further analysis
of this problem will be needed some day." --frank
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/5#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
