[Osgeo4w-trac] [osgeo4w] #7: Root install directory problems with folders with spaces (e.g. "C:/Program Files/")
OSGeo4W trac_osgeo4w at osgeo.org
Tue Jun 3 14:05:04 EDT 2008
Files/")
 Reporter:  jmckenna   |       Owner:  osgeo4w-dev at lists.osgeo.org
     Type:  defect     |      Status:  new
 Priority:  major      |   Milestone:  Beta Release
Component:  Installer  |     Version:  Alpha
 Keywords:             |
 - DOS window shortcut does not set the env variables properly if there is
 a space in the install path (error message is: "'C:\Program' is not
 recognized as an internal or external command")
 - during install, if a user browses to "C:\Program Files" the cygwin
 installer does not create an "OSGeo4w" directory....which means that all
 of osgeo4w's sub-folders now live  inside "Program Files"
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/7>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
