[Osgeo4w-trac] Re: [osgeo4w] #9: libjpeg does not support large
files
trac_osgeo4w at osgeo.org
Tue Jun 17 22:33:20 EDT 2008
#9: libjpeg does not support large files
Reporter: warmerdam | Owner: warmerdam
Type: defect | Status: assigned
Priority: major | Milestone:
Component: Package | Version:
Resolution: | Keywords: libjpeg
Changes (by warmerdam):
* status: new => assigned
* cc: hobu (added)
Comment:
I have discovered that I am using a slightly modified buildkit jpeg that
does indeed seem to be using a jconfig.h from unix/configure rather than
jconfig.h.vc. I'm not sure why.
However, I'm not clear on why this matters. It *seems* like applications
would normally use jpeg_stdio_src() and jpeg_stdio_dest() functions to
handle io and these are stdio based. I'm not sure how differences in
jconfig.h will alter how these operate. If the issue is needing large
file support, then it seems a custom src/dest handler would be required
(as is provided by GDAL).
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/9#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
