[Osgeo4w-trac] Re: [osgeo4w] #9: libjpeg is core dumping when doing a read header in ossim core engine.
OSGeo4W trac_osgeo4w at osgeo.org
Fri Jun 20 16:39:56 EDT 2008
  Reporter:  warmerdam  |       Owner:  warmerdam
      Type:  defect     |      Status:  assigned
  Priority:  major      |   Milestone:
 Component:  Package    |     Version:
Resolution:             |    Keywords:  libjpeg libtiff gdal
Changes (by warmerdam):
  * keywords:  libjpeg => libjpeg libtiff gdal
Comment:
 The problem was the ubiquitous "jpeg struct size" problem related to the
 type of boolean.
 I have rebuilt and re-uploaded libjpeg and libjpeg-devel (and source)
 using the jconfig.vc for jconfig.h.  I also had to rebuild and re-upload
 gdal with the new build.
 After this change I can access jpeg files and jpeg-in-tiff files properly
 from GDAL so I think we are in good shape.
 Garrett, could you update and confirm it fixes your problems as well?  If
 so, then close this ticket.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/9#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
