[Osgeo4w-trac] Re: [osgeo4w] #2: Add existing MS4W mapscript
packages
trac_osgeo4w at osgeo.org
Thu Jun 26 00:35:12 EDT 2008
#2: Add existing MS4W mapscript packages
Reporter: jmckenna | Owner: warmerdam
Type: task | Status: new
Priority: major | Milestone: Beta Release
Component: Package | Version: Alpha
Resolution: | Keywords:
Comment (by warmerdam):
OK, mapscript-python (stable and dev) are now packaged.
Tamas,
I would suggest you start out with c# bindings for 5.0.x stable. The
mapserver source file
(http://download.osgeo.org/osgeo4w/release/mapserver/mapserver-5.0.2-2-src.tar.bz2)
contains the nmake.opt file that was used. So using that it should be
fairly easy to recreate the mapscriptvars file (if you use that). The
main mapserver package also installs the include files which is helpful.
Does csharp use the mapscriptvars file?
Assefa - it would be helpful (I think) if the mapserver package installed
mapscriptvars in the install include directory along with the include
files. That would make it cleaner to build the various mapscripts in a
compatible way. What do you think?
Tamas - I think (hope) it is possible for MSVC80 compiled C# bindings to
call an MSVC7.1 compiled libmap.dll for the core. I don't want to see us
producing multiple copies of the mapserver package for different
compilers. If we have to do that, I think we have failed to some extent.
But it should be possible for you to produce C# mapscript packages for
.net 2.0 using MSVC8 and .net 1.1 using something older (VC7.1?). Or just
pick one .net framework that you want to support and only produce a
package for that.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/2#comment:4>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
