[Osgeo4w-trac] Re: [osgeo4w] #83: grass pkg: terminal not available until you exit the gui
OSGeo4W trac_osgeo4w at osgeo.org
Thu Aug 27 10:09:19 EDT 2009
Reporter:  hamish  |        Owner:  osgeo4w-dev at lists.osgeo.org
    Type:  defect  |       Status:  new
Priority:  major   |    Component:  Package
 Version:          |   Resolution:
Keywords:  grass   |
Comment (by hamish):
 Replying to [comment:5 dvictori]:
 > Just installed Grass6.4 svn3 (from osgeo4w) and I can't get
 > access to the DOS terminal when I run Grass wxpython. So I
 > don't know if the ticket does not apply to wxpython as Jeff says
 dumb question: do you start Grass wxpython using the Start Menu + version
 which says +DOS prompt, or just by double clicking on the
 desktop icon? (which doesn't give you a dos box)
 Hamish
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/83#comment:6>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
