[Osgeo4w-trac] Re: [osgeo4w] #120: gdal_polygonize missing
OSGeo4W trac_osgeo4w at osgeo.org
Fri Dec 4 14:26:31 EST 2009
Reporter:  lutra       |        Owner:  warmerdam
    Type:  defect      |       Status:  assigned
Priority:  major       |    Component:  Package
 Version:  1.0         |   Resolution:
Keywords:  pkg-gdal16  |
Changes (by warmerdam):
  * status:  new => assigned
Comment:
 On review, it appears gdal_polygonize is being installed as part of the
 gdal16 package.
 However, since GDAL 1.6 is not the primary GDAL version it is only put in
 C:\OSGeo4W\apps\gdal-16\bin which is only in the path after you run the
 gdal16.bat script.
 I think if QGIS's gdal tools intend to run the 1.6 tools, this bin
 directory should be prepended to the path in some fashion for qgis.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/120#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
