[Osgeo4w-trac] [osgeo4w] #45: osgeo4w-setup.exe update "In-use file" issue
OSGeo4W trac_osgeo4w at osgeo.org
Wed Feb 4 12:46:04 EST 2009
 Reporter:  mwtoews    |       Owner:  osgeo4w-dev at lists.osgeo.org
     Type:  defect     |      Status:  new
 Priority:  major      |   Milestone:
Component:  Installer  |     Version:
 Keywords:             |
 In the past day (Feb. 3-4, 2009) I've re-run C:\gnu\OSGeo4W\bin\osgeo4w-
 setup.exe (using Start > OSGeo4W > Setup) on my setup to add/update
 various packages, and when the program is at "Installing .. setup-1.0.3-6
 .. /bin/osgeo4w-setup.exe" I get a dialog (see also attached):
  '''In-use files detected'''
  Unable to extract /bin/osgeo4w-setup.exe -- the file is in use. Please
 stop all Cygwin processes and select "Retry", or select "Continue" to go
 on anyway (you will need to reboot).
  '''Retry'''/'''Continue'''
 It seems to me that this is circular logic, as the setup is running and
 trying to update itself from version 1.0.3-4 to 1.0.3-6.
 I've repeated this behaviour on two XPSP3 computers and on a Win2003
 Server.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/45>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
