[Osgeo4w-trac] Re: [osgeo4w] #13: "Local Package Directory" set to C:\Programmi\Mozilla Firefox
OSGeo4W trac_osgeo4w at osgeo.org
Fri Feb 20 19:04:49 EST 2009
  Reporter:  moovida      |       Owner:  osgeo4w-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  minor        |   Milestone:  Beta Release
 Component:  Installer    |     Version:
Resolution:               |    Keywords:
Comment (by mwtoews):
 I had this too, but I realized it was because I double-clicked the
 installer from Firefox's "Downloads" window, which I guess sets the
 current working directory for the installer to be the same as the parent
 application (Firefox).
 If you double-clicked the installer from Windows Explorer in the location
 where it downloaded (e.g., Desktop) then the local package directory will
 be based from that location.
 I'd expect the local package directory to default to the same directory as
 the installer, not the app work directory.
 E.g., path to installer:
 C:\Documents and Settings\User\Desktop\osgeo4w-setup.exe
 ... should use a default local package directory:
 I'd expect this to be a simple fix, except I don't know where to look.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/13#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
