[Osgeo4w-trac] Re: [osgeo4w] #37: grass: wxpython gui issues
trac_osgeo4w at osgeo.org
Mon Feb 23 03:28:23 EST 2009
Reporter: jachym | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone:
Component: Package | Version:
Resolution: | Keywords: GRASS
Comment (by hamish):
Replying to [comment:19 hamish]:
> Hi, just attempting my first OSGeo4W GRASS install. Downloaded today.
> packaging issues re. the wxpython GUI & epsg file:
> wxPython Startup: [Create new location from EPSG code]
> Error window:
> "Unable to read EPSG codes: [Errno 2] No such file or directory:
u'/c/OSGeo4W/share/proj\\epsg'
> [Ok], Choose EPSG Code window comes up.
> Path to the EPSG-codes file: [c/OSGeo4W/share/proj\epsg]
> [Browse], find it in the above location, [Ok]
> Error window:
> Unable to read EPSG codes: string index out of range
> [Ok]
> but if I know the number and put it in, it accepts it and expands to the
correct +proj terms. (I tried # 4326 ll/wgs84)
> So it's just the code browser which is unhappy in the end. But without
browsing to fix the "/c/...\epsg" to "C:\...\epsg" it gives me a Traceback
error in the DOS console (line 1567 KeyError: 4326).
Martin:
> Hopefully fixed in http://trac.osgeo.org/grass/changeset/35981.
similar problems in the Tcl/Tk GUI. From the startup screen:
Define new locations with ... [EPSG codes]
Path to the EPSG-codes file: /c/OSGeo4W/share/proj/epsg
EPSG code number of projection __________ [Browse]
if you click "browse EPSG codes", you get an error that the file can't be
found. If you browse for the EPSG file, the path becomes
`C:/OSGeo4W/share/proj/epsg` and then it all works: ie the nice code table
browsing, searching, & grabbing.
Hamish
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/37#comment:24>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
