[Osgeo4w-trac] Re: [osgeo4w] #35: DLL installation procedure
OSGeo4W trac_osgeo4w at osgeo.org
Thu Jan 22 02:08:38 EST 2009
  Reporter:  jef        |       Owner:  warmerdam
      Type:  defect     |      Status:  assigned
  Priority:  major      |   Milestone:  1.0 Release
 Component:  Installer  |     Version:  1.0
Resolution:             |    Keywords:
Changes (by warmerdam):
  * status:  new => assigned
  * owner:  osgeo4w-dev at lists.osgeo.org => warmerdam
Comment:
 I have:
  * Implemented a [wiki:dllupdate] utility program that will replace a
 windows\system32 dll with a newer version if we have one.  It is suitable
 for use from post install scripts.
  * I have factored libeay32.dll and ssleay32.dll out into a new [wiki:pkg-
 openssl].
  * I have added a post install script in this package to use dllupdate to
 install these files into \windows\system32 if we appear to have a newer
 version.
 I would appreciate testing of the new setting (via a standard package
 upgrade on a problem system).
 Leaving open pending this test.
 I would note that the PackagingInstructions have not been updated to
 reflect the availability of dllupdate (now part of [wiki:pkg-msvcrt]).
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/35#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
