[Osgeo4w-trac] Re: [osgeo4w] #37: grass: wxpython gui issues
OSGeo4W trac_osgeo4w at osgeo.org
Thu Jan 29 15:17:51 EST 2009
  Reporter:  jachym   |       Owner:  osgeo4w-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  major    |   Milestone:
 Component:  Package  |     Version:
Resolution:           |    Keywords:  GRASS
Comment (by martinl):
 Replying to [comment:7 jachym]:
 > in RC3:
 >  * wxdigit does not work - same problem (no module named grass6_wxdigit)
 >  * wxnviz - needs PyOpenGL - which is missing in the osgeo4w installator
 >  * maps are NOT displayed in the lists (prevous g.mlist issue)
 > So, only thing, which has changed since RC2:
 >  * commands are working - FIXED
 you are lucky;-) on my machine after updating from RC2 to RC3 I am not
 able even to start wxGUI...
 C:\Documents and Settings\landa\Plocha>grass64 -wxpython
   File "C:/OSGeo4W/apps/grass/grass-6.4.0RC3/etc/wxpython/gis_set.py",
 line 813,
  in <module>
     import gui_modules.gcmd as gcmd
   File
 "C:\OSGeo4W\apps\grass\grass-6.4.0RC3\etc\wxpython\gui_modules\gcmd.py",
 line 44, in <module>
     from win32file import ReadFile, WriteFile
 ImportError: DLL load failed: Uvedenß procedura nebyla nalezena.
   File "C:/OSGeo4W/apps/grass/grass-6.4.0RC3/etc/wxpython/wxgui.py", line
 69, in
  <module>
     import gui_modules.utils as utils
   File
 "C:\OSGeo4W\apps\grass\grass-6.4.0RC3\etc\wxpython\gui_modules\utils.py",
  line 25, in <module>
     import gcmd
   File
 ImportError: DLL load failed: Procedure not found
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/37#comment:8>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
