[Osgeo4w-trac] [osgeo4w] #94: qgis-dev : missing gdal16.dll dependency
OSGeo4W trac_osgeo4w at osgeo.org
Sat Jun 27 15:28:29 EDT 2009
Reporter:  mwtoews  |       Owner:  osgeo4w-dev at lists.osgeo.org
    Type:  defect   |      Status:  new
Priority:  major    |   Component:  Package
 Version:           |    Keywords:
 After installing/updating qgis-dev via osgeo4w setup, on starting qgis-
 dev, I see an error message:
   This application has failed to start because gdal16.dll was not found.
 Re-installing the application may fix this problem.
 I have reproduced this message on a computer that updated qgis-dev, and on
 another that installed osgeo4w for the first time. Re-running setup and
 manually selecting the gdal16 package solved this dependency.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/94>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
