[Osgeo4w-trac] [osgeo4w] #112: apt: add switch for download cache directory
OSGeo4W trac_osgeo4w at osgeo.org
Thu Oct 8 03:14:06 EDT 2009
Reporter:  maphew       |       Owner:  maphew
    Type:  enhancement  |      Status:  new
Priority:  major        |   Component:  Documentation
 Version:               |    Keywords:
 Apt could use an optional parameter to specify the location of the package
 cache directory. This will make it easier to test concurrent o4w installs
 on the same machine, or different machines across a network, and lighten
 the bandwith load by letting them share the same cache directory.
 Also consider this: if --cache=... is used with "apt setup" the cache
 location is written into .../etc/setup/lastcache, which would help #43
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/112>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
