[Osgeo4w-trac] [osgeo4w] #172: sslmode error when adding PostGIS layer
OSGeo4W trac_osgeo4w at osgeo.org
Wed Jul 28 06:59:43 EDT 2010
Reporter:  morisimo  |       Owner:  osgeo4w-dev@…
    Type:  defect    |      Status:  new
Priority:  critical  |   Component:  Package
 Version:  Alpha     |    Keywords:  PostGIS, SSLmode
 I am working on Windows XP SP2 and I am running 3 QGIS packages via the
 OSGEO4W package manager, 1.0, 1.4 and 1.5.
 I am trying to add a PostGIS layer from my PostGIS server where I need to
 connect via SSL in "Require" mode.
 I can connect to my database via the pgAdmin console, as well as via the
 PostGIS Manager plugin.
 However, when I try to add a PostGIS layer, I get the following error
 message:
 ''"The database said: sslmode value "require" invalid when SSL support is
 not compiled in"''
 I do not get this error at all when adding a PostGIS layer in the
 standalone install of QGIS 1.4.0.
 Any help on this issue would be much appreciated!
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/172>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
