[Osgeo4w-trac] Re: [osgeo4w] #161: gdal utilities issues
OSGeo4W trac_osgeo4w at osgeo.org
Tue Mar 16 09:14:50 EDT 2010
Reporter:  lutra                 |        Owner:  osgeo4w-dev at lists.osgeo.org
    Type:  defect                |       Status:  new
Priority:  major                 |    Component:  Package
 Version:                        |   Resolution:
Keywords:  gdal, gdal utilities  |
Comment (by jef):
 Replying to [ticket:161 lutra]:
 > *) If during the osgeo4w install it is added *just* the gdal16/gdal16-
 python
 > libraries/packages, then all the gdal utilities that are wrote in python
 fail
 > to work. The error is always like (both from  the command line and from
 the
 > plugin):
 GDAL 1.5 is currently the default GDAL in OSGeo4W and once installed works
 out of the box.
 QGIS however uses GDAL 1.6 (to allow attribute additions to shape files).
 So you probably only installed QGIS and got GDAL 1.6 with it - and no GDAL
 1.5.
 If you want to use GDAL 1.6 from the command line you need to run
 {{{gdal16.bat}}} manually first.  Running GDAL 1.5 binaries after that is
 probably not a good idea either.
 If you start QGIS using the desktop/start menu link {{{gdal16.bat}}} is
 run
 automatically.  So everything should be fine from within QGIS.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/161#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
