[Osgeo4w-trac] Re: [osgeo4w] #161: gdal utilities issues
OSGeo4W trac_osgeo4w at osgeo.org
Wed Mar 17 04:50:14 EDT 2010
Reporter:  lutra                 |        Owner:  osgeo4w-dev at lists.osgeo.org
    Type:  defect                |       Status:  new
Priority:  major                 |    Component:  Package
 Version:                        |   Resolution:
Keywords:  gdal, gdal utilities  |
Comment (by lutra):
 > Now it's explicit becouse without gdal lib the merge tools return this
 error.
 > But how can I import the gdal16 lib in python?
 [[BR]]
 another important question, once you'll find a way to call gdal16, it will
 be enough or users will have in any case to run gdal16.bat from the
 osgeo4w shell before?
 [[BR]]
 > Now remain this, finding the issue will be more difficult here:
 > > 1) gdal16 executables crash
 > This is sure not related with gdaltools-plugin, I re-tried by osgeo4w
 shell (to be very very sure) and it crashes.
 [[BR]]
 For what it's worth, I made a *dirt* experiment that gave good results: I
 copied fwtools gdal utilities executables into the osgeo4w gdal16 binary
 folder (overwriting the files): they works fine under Seven with both the
 command line and from the gdal tools plugin, no crashes at all.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/161#comment:18>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
