[Osgeo4w-trac] Re: [osgeo4w] #166: Invalid package qt4-doc-4.5.2-5
OSGeo4W trac_osgeo4w at osgeo.org
Fri May 7 02:51:30 EDT 2010
Reporter:  alexbruy  |        Owner:  osgeo4w-dev at lists.osgeo.org
    Type:  defect    |       Status:  reopened
Priority:  major     |    Component:  Package
 Version:            |   Resolution:
Keywords:  qt4-doc   |
Changes (by alexbruy):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 Problem still there. Packages qt4-doc-4.5.2-5.tar.bz2, qt4-
 doc-4.5.2-6.tar.bz2 and qt4-doc-4.5.2-7.tar.bz2 can't be installed or
 uncompressed with external archiever. Here is log from OSGeo4W msys
 console when I try to unpack qt4-doc-4.5.2-7.tar.bz2
 apps/Qt4/doc/html/images/designer-resources-using.png
 apps/Qt4/doc/html/images/designer-screenshot-small.png
 bzip2: Compressed file ends unexpectedly;
         perhaps it is corrupted?  *Possible* reason follows.
 bzip2: error 0
         Input file = (stdin), output file = (stdout)
 It is possible that the compressed file(s) have become corrupted.
 You can use the -tvv option to test integrity of such files.
 You can use the `bzip2recover' program to *attempt* to recover
 data from undamaged sections of corrupted files.
 tar: 296 garbage bytes ignored at end of archive
 tar: Unexpected EOF in archive
 tar: Error is not recoverable: exiting now
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/166#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
