[Osgeo4w-trac] Re: [osgeo4w] #34: proj: projects.h missing
OSGeo4W trac_osgeo4w at osgeo.org
Sun Feb 20 05:10:00 EST 2011
Reporter:  jef     |       Owner:  warmerdam
    Type:  defect  |      Status:  new
Priority:  minor   |   Component:  Package
 Version:          |    Keywords:  pkg-proj
Comment(by hamish):
 I've just been made aware of this bug. I'm responsible for adding the
 include projects.h to GRASS's g.region, to print the convergence angle (at
 the center of the current region bounds) as noted by Jürgen in comment:3.
 As projects.h ships with all the proj-dev packages I've ever come across,
 and grass has a rather intertwined code relationship with proto- and
 modern proj4, at the time mixing it up a bit more it didn't seem like it
 would be a problem.
 this patch was prepared to work around the problem:
 https://trac.osgeo.org/grass/attachment/ticket/1271/grass64svn_osgeo4w_gregion.patch
 but I don't like cloning code unless it is absolutely necessary. is it?
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/34#comment:5>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
