[Osgeo4w-trac] [osgeo4w] #228: GRASS6.4.1 is not well work.
OSGeo4W trac_osgeo4w at osgeo.org
Fri May 20 04:28:25 EDT 2011
Reporter:  hhayashi  |       Owner:  osgeo4w-dev@…
    Type:  defect    |      Status:  new
Priority:  critical  |   Component:  Package
 Version:            |    Keywords:  GRASS6.4.1
 We tested new GRASS6.4.1 in OSGeo4w using Windows 7 Japanese version.
 Unfortunately,many menu strings and message strings did not convert to
 Japanese.
 Tool tips string at menu buttons change to show "Add raster map
 layer(Ctrl+R)" , not translate to Japanese (for example) and it dose not
 work.
 And "open raster layers" button can not create dialog.
 But in GRASS 6.4.0, we already fixed those translation and checked them
 all.
 --(command console)---------------
 3D view mode not available
 Reason: No module named lib.grass
 Note that the wxGUI's 3D view mode is currently disabled on
 MS Windows (hopefully this will be fixed soon). Please keep
 an eye out for updated versions of GRASS. In the meantime
 you can use "NVIZ" from the File menu.
 Vector digitizer not available
 Reason: No module named grass6_wxvdigit
 Note that the wxGUI's vector digitizer is currently disabled
 (hopefully this will be fixed soon). Please keep an eye out
 for updated versions of GRASS. In the meantime you can use
 "v.digit" from the Develop Vector menu.
   File
 "C:/OSGeo4W/apps/grass/grass-6.4.1/etc/wxpython/wxgui.py",
 line 1180, in OnAddRaster
 self.curr_page.maptree.AddLayer('raster')
   File "C:\OSGeo4W\apps\grass\grass-6.4.1\etc\wxpython\gui_m
 odules\layertree.py", line 821, in AddLayer
 self.PropertiesDialog(layer, show=True)
 odules\layertree.py", line 882, in PropertiesDialog
 parentframe=self)
 odules\menuform.py", line 2049, in ParseCommand
 self.grass_task = self.ParseInterface(cmd)
 odules\menuform.py", line 2020, in ParseInterface
 tree = etree.fromstring(getInterfaceDescription(cmd[0]))
   File
 "C:\OSGeo4W\apps\Python25\lib\xml\etree\ElementTree.py",
 line 963, in XML
 parser.feed(text)
   File
 line 1245, in feed
 self._parser.Parse(data, 0)
 xml.parsers.expat
 ExpatError
 not well-formed (invalid token): line 8, column 8
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/228>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
