[Osgeo4w-trac] Re: [osgeo4w] #169: o-help doesn't catch gdal16 or gdal17 commands
OSGeo4W trac_osgeo4w at osgeo.org
Sun Feb 5 04:24:01 EST 2012
Reporter:  maphew            |        Owner:  maphew
    Type:  enhancement       |       Status:  closed
Priority:  major             |    Component:  Documentation
 Version:                    |   Resolution:  wontfix
Keywords:  pkg-shell o-help  |
Changes (by maphew):
  * status:  assigned => closed
  * resolution:  => wontfix
Old description:
> o-help.bat from [[pkg-shell]] is unaware of the gdal16 or gdal17
> packages, or any other package under ./apps which might add directories
> to path. Consequently o-help is not as helpful as it could be.
> It would be relatively straight forward to add IF..EXIST tests for
> apps/gdal16. Perhaps a more generalised algorithm could be devised to
> automatically search anything in %path% under %osgeo4w_root% without too
> much work?
New description:
 o-help.bat from [wiki:pkg-shell] is unaware of the gdal16 or gdal17
 packages, or any other package under ./apps which might add directories to
 apps/gdal16. Perhaps a more generalized algorithm could be devised to
 much work?
Comment:
 I've decided this isn't worth pursuing. I've not thought of a way of
 reliably chasing down which other o4w dirs in path are worth tripping
 through and listing commands of. Calling o-help is slow enough as it is
 already on initial load without adding more dirs to process. Also the
 gdal-XX-version are not mainstream anyway.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/169#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
