[Osgeo4w-trac] Re: [osgeo4w] #36: change app launch bat files to call o4w_env.bat
OSGeo4W trac_osgeo4w at osgeo.org
Wed Feb 8 17:44:11 EST 2012
Reporter:  maphew  |        Owner:  maphew
    Type:  defect  |       Status:  closed
Priority:  major   |    Component:  Package
 Version:          |   Resolution:  fixed
Keywords:          |
Changes (by maphew):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 Closing ticket. This is best handled by updating the
 [PackagingInstructions#Applicationbatchfiletemplate Packaging Instructions
 # batch file template] with the recommended approach (done) and letting
 the maintainers adjust as suits them.
 Also a tweak to the original suggestion to avoid hard coding osgeo4w_root:
 If `bin\foo.bat` use:
 @echo off
 call "%~dp0\o4w_env.bat"
 start "Foo window title" /B "%OSGEO4W_ROOT%\bin\foo.exe" %*
 @echo on
 If `apps\foo\foo.bat` use:
 @echo off
 call "~dp0\..\..\bin\o4w_env.bat
 start "Foo window title" /B "%OSGEO4W_ROOT%\apps\foo\foo.exe" %*
 @echo on
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/36#comment:5>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
