[Osgeo4w-trac] Re: [osgeo4w] #272: osgeo4w - PROJ.4 strings do not work with GDAL
OSGeo4W trac_osgeo4w at osgeo.org
Thu Feb 23 15:02:37 EST 2012
Reporter:  tcgeophysics  |        Owner:  osgeo4w-dev@…
    Type:  defect        |       Status:  closed
Priority:  major         |    Component:  Package
 Version:                |   Resolution:  fixed
Keywords:                |
Changes (by tcgeophysics):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:1 jef]:
 > try quotes:
 > gdalwarp -t_srs "+proj=utm +zone=11 +datum=WGS84" input.tif
 output_utm11.tif
 I did not think about that syntax issue as simple quote are used in
 examples on the gdalwarp manual page.
 Double quotes work perfectly!
 Thanks
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/272#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
