[Osgeo4w-trac] [osgeo4w] #276: Osgeo4w.bat problem with setting root
OSGeo4W trac_osgeo4w at osgeo.org
Wed Mar 14 02:15:15 EDT 2012
Reporter:  maphew  |       Owner:  maphew
    Type:  defect  |      Status:  new
Priority:  major   |   Component:  Package
 Version:          |    Keywords:  pkg-shell
 Osgeo4w.bat has a line in it to remove the trailing backslash from the
 auto-generated OSGEO4W_ROOT variable. Most of the time this works just
 fine, however if the root happens to be the top of a drive instead of a
 folder unexpected things can happen.
 The immediate fix is to REMark out the line, as shown below. It should be
 safe and have no functional repercussions.
 rem Remove trailing backslash
 rem set OSGEO4W_ROOT=%OSGEO4W_ROOT:~0,-1%
 The purpose of the line is largely cosmetic, it prevents a double
 backslash appearing in things like `PATH=%OSGEO4W_ROOT%\bin;` (becomes
 `PATH=C:\Osgeo4w\\bin;`). In testing Windows seems to ignore double
 slashes faithfully and completely.
 Without the fix in place, if osgeo4w_root is a drive letter (`X:`), then
 it become relative to whatever the current directory on the drive is
 instead of the absolute location.
 The next release of [wiki:pkg-shell] will have a fix.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/276>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
