[Osgeo4w-trac] Re: [osgeo4w] #281: apt upgrade error "ValueError:
list.remove(x): x not in list"
trac_osgeo4w at osgeo.org
Mon Mar 26 17:09:23 EDT 2012
#281: apt upgrade error "ValueError: list.remove(x): x not in list"
Reporter: maphew | Owner: maphew
Type: defect | Status: assigned
Priority: major | Component: Package
Version: | Keywords: pkg-apt
Changes (by maphew):
* status: new => assigned
Comment:
Found the cause: the current qgis package uses a leading `./` in the
archive path whereas the usual method is not have a prefix at all, e.g.
`apps/qgis` rather than `./apps/qgis`.
Since from a path handling point of view both are valid, and should point
to the same place, I guess this is a bug in apt (especially since
setup.exe seems okay with it).
Installation is actually very nearly complete. excepting the step of
renaming `qgis.bat` to `qgis.bat.done` in the installed files manifest.
To finish the install manually:
* open `etc/setup/qgis.lst.gz` and change `./etc/postinstall/qgis.bat` to
`./etc/postinstall/qgis.bat.done`
* edit `etc/setup/installed.db` and add `qgis qgis-1.7.4-4.tar.bz2 0`
''(Hmmm, there's another new ticket here. Apt doesn't roll back to initial
state on a botched install attempt.)''
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/281#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
