[Osgeo4w-trac] Re: [osgeo4w] #280: Create ECW plugin for gdal-1.9
OSGeo4W trac_osgeo4w at osgeo.org
Tue Mar 27 07:51:45 EDT 2012
Reporter:  jpalmer  |       Owner:  warmerdam
    Type:  task     |      Status:  assigned
Priority:  major    |   Component:  Package
 Version:           |    Keywords:  pkg-gdal-ecw
Comment(by jef):
 Replying to [comment:4 avlisad]:
 > Since different versions of QGis and gdal(lib) can coexist and only QGis
 needs GDAL_DRIVER_PATH to be set in order to find gdal plugins, that
 variable must be set in qgis.bat and qgis-dev.bat to
 %OSGEO4W_ROOT%\bin\gdalplugins\@GDAL_VERSION@, where @GDAL_VERSION@ is the
 version of gdal used to build QGis.
 What's your point?  QGIS is built with 1.9  (but yes, the entry was still
 from when GDAL 1.7 was the default GDAL in OSGeo4W and QGIS was build with
 1.8).
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/280#comment:5>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
