[Osgeo4w-trac] Re: [osgeo4w] #282: python path getting overwritten
OSGeo4W trac_osgeo4w at osgeo.org
Fri Mar 30 01:51:09 EDT 2012
Reporter:  lpinner  |       Owner:  maphew
    Type:  defect   |      Status:  assigned
Priority:  minor    |   Component:  Package
 Version:           |    Keywords:  python
Comment(by lpinner):
 Replying to [comment:3 maphew]:
 > I don't know that we can rely/assume the call order for the batch files
 is alphabetical.
 I don't think the order is important, I only mentioned it as it was the
 OTB pythonpath that was getting overwritten, not the other way around.
 Should probably do something similar for all batch files that set
 environment variables that might also be set/reset/extended by another
 batch file.
 > I'll use the second example for now. Long term I'd rather intelligently
 only add path items which don't exist already (here and in [wiki:pkg-
 shell]), something that appears to be frustratingly hard on Windows.
 It's kinda ugly, but what about something like:
 rem Couldn't figure out out to get the output of findstr
 rem into a variable, so use errorlevel instead
 rem Idea from http://stackoverflow.com/questions/2634959/2-batch-string-
 questions
 set testpythonpath=%OSGEO4W_ROOT%\apps\Python27
 echo %PYTHONPATH%|findstr /i "%testpythonpath%">nul
 IF  %errorlevel%==0 goto EXIT
 IF "%PYTHONPATH%"=="" (
     SET PYTHONPATH=%testpythonpath%
 ) ELSE (
     SET PYTHONPATH=%PYTHONPATH%;%testpythonpath%
 :EXIT
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/282#comment:4>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
