[Osgeo4w-trac] [osgeo4w] #309: Upgrade FileGDB GDAL plugin to 1.9.2
OSGeo4W trac_osgeo4w at osgeo.org
Mon Jan 21 12:20:58 PST 2013
Reporter:  jpalmer           |        Owner:  warmerdam
    Type:  enhancement       |       Status:  closed
Priority:  major             |    Component:  Package
 Version:                    |   Resolution:  fixed
Keywords:  GDAL OGR FileGDB  |
Changes (by saultdon):
  * status:  reopened => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:4 jef]:
 > Replying to [comment:3 saultdon]:
 > > I've also uninstalled and re-installed the gdal-filegdb component in
 the installer and still get the same error.
 > Did you add the DLL FileGDBAPI.dll from the ESRI SDK?
 The ogr_FileGDB.dll file that it's complaining about is in the
 ...\bin\gdalplugins\1.9 folder already.
 I placed the FileGDB API DLLs into '''C:\GIS\Programs\FileGDB\bin64'''
 which I then added to my PATH.
 In the osgeo4w shell, the PATH that I've setup is seen in the output of
 '''echo %PATH%'''.
 The DLLs I grabbed are from the VS2010 version, so I switched them with
 the VS2008 version, still get the invalid win32 application error?
 I guess the hint here, was the "invalid win32" application error. This
 FileGDB as it's compiled requires the 32-bit FileGDB SDK DLLs, not the
 64bit ones!
 Once I '''replaced the bin64 folder''' in my C drive with the regular
 32bit '''bin''' folder, and updated the PATH for the FileGDB, it works.
 Thanks for working on this, and having patience with me =)
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/309#comment:5>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
