[Osgeo4w-trac] [osgeo4w] #334: Crash in QtWebKit4.dll
OSGeo4W trac_osgeo4w at osgeo.org
Mon Jan 21 22:52:15 PST 2013
Reporter:  mkuhn   |       Owner:  osgeo4w-dev@…
    Type:  defect  |      Status:  new
Priority:  major   |   Component:  Package
 Version:          |    Keywords:
 When using d3 libraries builtin classed method, without initializing the
 class prior to this, a SegFault occurs at a random location in the code
 and therefore hard to debug.
 Most probably this is related to the following bug report.
 http://code.google.com/p/chromium/issues/detail?id=57797
 Newer versions of webkit don't have this bug, so an update of the library
 in question should solve this problem.
 Workaround: before using classed (and probably anything that makes use of
 classList) initialize the objects class attribute with an empty string.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/334>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
