[Osgeo4w-trac] [osgeo4w] #431: points2grid depends on Visual Studio 2013 redistributables
OSGeo4W trac_osgeo4w at osgeo.org
Mon Aug 18 21:21:47 PDT 2014
Reporter:  mwtoews  |       Owner:  osgeo4w-dev@…
    Type:  defect   |      Status:  new
Priority:  minor    |   Component:  Package
 Version:           |    Keywords:
 When attempting to use points2grid from an OSGeo4W Shell, I see a System
 Error dialog:
 > The program can't start because MSVCP120.dll is missing from your
 computer. Try reinstalling the program to fix this problem.
 This was installed from the 64-bit version of OSGeo4W on Windows 7.
 Does OSGeo4W install other MSVC redistributables as dependencies? If so,
 then it should also install this one. Installing it fixes the problem.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/431>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
