[Osgeo4w-trac] [osgeo4w] #433: Upgrade request for pyqt4 version in 32bits installer
OSGeo4W trac_osgeo4w at osgeo.org
Fri Aug 22 03:26:39 PDT 2014
Reporter:  Rhaubourg    |       Owner:  osgeo4w-dev@…
    Type:  enhancement  |      Status:  new
Priority:  major        |   Component:  Package
 Version:               |    Keywords:  pyqt
 pyqt4 version in 32 bit installer is late compared to 64 bit. currently
 the 32 bit windows build uses pyqt 4.8.3 when some use case in the API
 require 4.8.4 or higher.
 See  following qgis issue:
 https://hub.qgis.org/issues/10927
 At least two plugin are broken for 32 bits versions, if someone has time
 for such an upgrade, that would help a lot.
 Cheers
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/433>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
