[Osgeo4w-trac] [osgeo4w] #421: BAG uncertainty NoData value should be 1000000, not 0
OSGeo4W trac_osgeo4w at osgeo.org
Fri May 23 10:45:34 PDT 2014
Reporter:  jdvarner  |       Owner:  osgeo4w-dev@…
    Type:  defect    |      Status:  new
Priority:  minor     |   Component:  Package
 Version:            |    Keywords:  GDAL BAG
 The NODATA value for the uncertainty in BAG files is being reported as 0.
 However, I think it should be set to 1000000.
 There's some inconsistency in the documentation:
 From OpenNavSurf
 (http://www.opennavsurf.org/papers/BAG_FSD_Release_1.5.1.pdf, page 11):
 "The *unknown* state for uncertainty is defined to be 0.0"
 From IHO S-102 Format Standard
 (http://www.iho.int/iho_pubs/standard/S-102/S-102_Ed1.0.0_Apr12.pdf, page
 34):
 "The *undetermined* state for uncertainty is defined to be 1,000,000.0
 (1.0e6)."
 I've checked a sampling of BAGs that we archive here at NOAA/NGDC. All of
 them have 1000000 in the uncertainty band in areas with no data.
 Thanks to Mike Wilburn from Esri for pointing out this issue.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/421>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
