[Osgeo4w-trac] [osgeo4w] #473: create a geos-c++ package
OSGeo4W trac_osgeo4w at osgeo.org
Mon Jan 11 06:03:48 PST 2016
Reporter:  rashadkm     |       Owner:  osgeo4w-dev@…
    Type:  enhancement  |      Status:  new
Priority:  major        |   Component:  Package
 Version:               |  Resolution:
Keywords:               |
Comment (by rashadkm):
 recalling the discussion on geos-devel list;
 geos c++ api is fully supported and can be used if the project wants to.
 So ossim is using it without any violation. It is not a serious bug is
 ossim that it uses geos c++. Why should the package upgrade be blocked
 because of ossim using geos c api. If there comes a problem because of
 geos-c++ api, the other packages must be given a clear documentation
 somewhere in osgeo4w page or atleast even try to cope with the issue. Not
 the other way around. Only to include a package in osgeo4w, the upstream
 should rewrite a part of its code which is working and is not a violation
 of anything that osgeo4w stands for.
 Imagine if ossim someday decides to move to geos c api. the there comes
 otb that uses ossim c++ api. And unfortunately, there is no C api for
 ossim. So the packaging blocked.
 Is the osgeo4w packages are specific to C projects. I never know. I am
 completely lost on this point. All I get was a humble request to move to c
 api?
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/473#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
