[Osgeo4w-trac] [osgeo4w] #531: PATH to WBEM is wrong
OSGeo4W trac_osgeo4w at osgeo.org
Fri May 26 20:31:01 PDT 2017
Reporter:  tobwen  |      Owner:  osgeo4w-dev@…
    Type:  defect  |     Status:  new
Priority:  major   |  Component:  Installer
 Version:          |   Keywords:  installer, WBEM, path
 ''%OSGEO4W_ROOT%\bin\o4w_env.bat'' tries to set a clean path variable to:
 REM start with clean path
 set path=%OSGEO4W_ROOT%\bin;%WINDIR%\system32;%WINDIR%;%WINDIR%\WBem
 Actually, the path to ''WBem'' is wrong, the correct one is:
 {{{%WINDIR%\system32\wbem}}}
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/531>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
