[Osgeo4w-trac] [osgeo4w] #550: OSGeo4W-64 bit: lasinfo crashes with an entry point not found
OSGeo4W trac_osgeo4w at osgeo.org
Sun Jan 21 08:24:42 PST 2018
Reporter:  hellik    |       Owner:  osgeo4w-dev@…
    Type:  defect    |      Status:  new
Priority:  critical  |   Component:  Package
 Version:            |  Resolution:
Keywords:  las       |
Comment (by hobu):
 > I took liberty to create the new laszip2 package (1) and updated liblas
 setup.hint for new laszip2 dependency. I did these changes only for
 x64_64. So we can finally re-enable liblas support in GRASS.
 Were there any patches to LASzip's CMakeLists.txt to support this? Please
 upstream them and I'll merge.
 > Let me know if laszip2 package as workaround is OK for you. Then I would
 ask @hobu to remove laszip v2 packages from laszip directory (I don't have
 rights to do it).
 Done. I have hidden them so they could be restored if necessary, however.
 Thanks for the work on this topic. Sorry for making a mess.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/550#comment:12>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
