[Osgeo4w-trac] [osgeo4w] #574: gdalbuildvrt fails handling wildcards under Win1 1803
OSGeo4W trac_osgeo4w at osgeo.org
Fri Jun 15 10:26:22 PDT 2018
Reporter:  Langlaeufer  |      Owner:  osgeo4w-dev@…
    Type:  defect       |     Status:  new
Priority:  major        |  Component:  Package
 Version:               |   Keywords:  GDAL,
 After Spring update of Windows 10 (to r1803) gdalbuildvrt fails to handle
 wildcards.
 Behavior.
 computer 1: Programm is running without messages, no output is generated.
 computer 2: programm is running, showing error "missing file", result is
 generated but the first file of each folder is missing. The filename of
 the missing file was only 1 character from the filename of the missed
 file. It seams that a inclomplete string was created by processing the
 wildcard.
 affected version. GDAL comming with QGIS 3.0.x packagees
 it is not a GDAL bug. GISInternals x64 MSVC17 build of GDAL don't show
 this problem.
 I guess the library used for building GDAL binaries is not compatible with
 current version of windows 10.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/574>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
