[Osgeo4w-trac] [osgeo4w] #590: wrong version of numpy installed with gdal-python
trac_osgeo4w at osgeo.org
Thu Jan 24 02:48:59 PST 2019
Reporter: monstermushroom | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Keywords:
on a clean windows 32 bit build, if installing msys, gdal, gdal-python,
python and python-numpy:
open msys
$ python
Python 2.7.14 (v2.7.14:84471935ed, Sep 16 2017, 20:19:30) [MSC v.1500 32
bit (Intel)] on win32
Type "help", "copyright", "credits" or "license" for more information.
>>> import numpy
>>> from osgeo import gdal
>>> from osgeo import gdalnumeric
RuntimeError: module compiled against API version 0xc but this version of
numpy is 0x7
File "<stdin>", line 1, in <module>
File "C:\OSGeo4W\apps\Python27\lib\site-packages\osgeo\gdalnumeric.py",
line 2, in <module>
from osgeo.gdal_array import *
File "C:\OSGeo4W\apps\Python27\lib\site-packages\osgeo\gdal_array.py",
line 17, in <module>
_gdal_array = swig_import_helper()
line 16, in swig_import_helper
return importlib.import_module('_gdal_array')
File "C:\OSGeo4W\apps\Python27\lib\importlib\__init__.py", line 37, in
import_module
__import__(name)
ImportError: No module named _gdal_array
>>> exit()
In OSGEo4w, the only option is to download python-numpy version 1.7.0, and
the alternate version is 1.5, although these are very old, and the latest
versions under osgeo seem to be 1.12 and 1.15.
This appears to be because the python version is included in the file
names of the older packets versions on the download site, making them seem
as if they are newer.
http://download.osgeo.org/osgeo4w/x86/release/python/python-numpy/
python-numpy-1.11.0-1.tar.bz2 18-Oct-2017 20:37 5.3M
python-numpy-1.12.1+mkl-1.tar.bz2 10-Apr-2017 11:41 17M
python-numpy-1.12.1-1.tar.bz2 06-Apr-2017 08:14 5.4M
python-numpy-1.15.4-1.tar.bz2 02-Jan-2019 17:38 7.6M
python-numpy-2.5-1.1.0-1.tar.bz2 22-Jun-2008 20:12 2.4M
python-numpy-2.7-1.5.1-1.tar.bz2 07-May-2011 08:08 2.1M
python-numpy-2.7-1.7.0-1.tar.bz2 28-May-2013 15:10 2.4M
The result of the error is that matplotlib and pandas will no longer
function, since 1.7 is below their minimum versions, and also any script
using gdal_calc, the gdal raster calculator, will also fail.
Is there a workaround for this? Can I make the setup look for the right
version (which is probably 12?)
Thanks,
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/590>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
