[Osgeo4w-trac] [osgeo4w] #592: GRASS 7.6 implies a OSGEO4W_ROOT
OSGeo4W trac_osgeo4w at osgeo.org
Fri Jan 25 12:48:32 PST 2019
Reporter:  jef     |      Owner:  osgeo4w-dev@…
    Type:  defect  |     Status:  new
Priority:  major   |  Component:  Package
 Version:          |   Keywords:  grass
 `grass76.bat.tmpl` does contain a fixed path instead of `@osgeo4w@`, that
 not necessarily corresponds to the actual `%OSGEO4W_ROOT% - the 32bit
 doesn't even match the default install path.
 Hint: the batch file could be static and use the following instead (like
 `qgis.bat`)
 call "%~dp0\o4w_env.bat"
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/592>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
