[Osgeo4w-trac] [osgeo4w] #641: rbatch breaks QGIS/Qt
OSGeo4W trac_osgeo4w at osgeo.org
Sat Oct 17 10:54:43 PDT 2020
Reporter:  jef         |       Owner:  hellik
    Type:  defect      |      Status:  closed
Priority:  major       |   Component:  Package
 Version:              |  Resolution:  fixed
Keywords:  pkg-rbatch  |
Comment (by andreaerdna):
 Yet another issue report https://github.com/qgis/QGIS/issues/39310.
 In https://github.com/qgis/QGIS/issues/39310#issuecomment-707006224 is
 also reported the following issue with qgis-grass-plugin7 3.14.16-3:
 On a clean Windows 10 machine ... on activating the GRASS plugin I get
 2020-10-12T10:32:43 WARNING GRASS init error : Problem in GRASS
 initialization, GRASS provider and plugin will not work : Module built
 against version 8bcecc9a6 but trying to use version d8fbd49af. You need to
 rebuild GRASS GIS or untangle multiple installations.
 that I guess depends on the fact that QGIS package is 3..14.16-2 and the
 GRASS plugin one is 3.14.16-3. Downgrading the latter to -2 and everything
 is ok.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/641#comment:19>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
