[Osgeo4w-trac] [osgeo4w] #641: rbatch breaks QGIS/Qt
OSGeo4W trac_osgeo4w at osgeo.org
Mon Sep 14 11:00:29 PDT 2020
Reporter:  jef         |       Owner:  hellik
    Type:  defect      |      Status:  closed
Priority:  major       |   Component:  Package
 Version:              |  Resolution:  fixed
Keywords:  pkg-rbatch  |
Comment (by jef):
 Replying to [comment:10 baswein]:
 > I'm happy to try to rename it but this is all a bit over my head. What
 do I change it to?
 Just go into `%ProgramFiles%` and rename `RStudio` and try to start QGIS.
 But that's just to verify that it's the actual cause of the issue - which
 I think it is.  It's not an actual solution.
 Removing the lines from `env.bat` should help too, but that way GRASS
 won't be able to call it anymore.  Wrappers that are placed in an
 directory already in PATH could help with that - but I don't know which
 binaries are actually called, for which wrappers would need to be
 produced…
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/641#comment:11>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
