[Osgeo4w-trac] [osgeo4w] #641: rbatch breaks QGIS/Qt
OSGeo4W trac_osgeo4w at osgeo.org
Mon Sep 21 13:12:33 PDT 2020
Reporter:  jef         |       Owner:  hellik
    Type:  defect      |      Status:  closed
Priority:  major       |   Component:  Package
 Version:              |  Resolution:  fixed
Keywords:  pkg-rbatch  |
Comment (by andreaerdna):
 As [https://www.facebook.com/groups/GisItalia/permalink/10158857068641385/
 reported] by an Italian user on a facebook support group, it seems that
 updating qgis-grass-plugin7 to version 3.14.16-3 or also installing today
 from scratch qgis with grass (with qgis-grass-plugin7 3.14.16-3) via the
 OSGeo4W network installer on a Windows 8.1 system, does not solve the
 issue.
 The reported error is
 [[Image(https://scontent-
 mxp1-1.xx.fbcdn.net/v/t1.0-9/119985426_10223475069014566_1816775042224108409_n.jpg?_nc_cat=111&_nc_sid=ca434c&_nc_ohc=wW2uHEj0808AX8_tHL9&_nc_ht
 =scontent-mxp1-1.xx&oh=64d4339ebc17b57654022f6021e819d7&oe=5F8D4417,
 480px)]]
 The procedure entry point
 ?glyphCache at QFontEngine@@QEBAPEAVQFontEngineGlyphCache@@PEBXW4GlyphFormat at 1@AEBVQTransform@@@Z
 could not be located in the dynamic link library
 C:\OSGEO\apps\qtS\bin\Qt5OpenGL.dll.
 In his system is installed RStudio.
 qgis-bin-g7.env contains the following value for the PATH variable:
 PATH=C:\OSGEO4~2\apps\qgis\bin;C:\OSGEO4~2\apps\grass\grass78\lib;C:\OSGEO4~2\apps\grass\grass78\bin;C:\OSGEO4~2\apps\Python37;C:\OSGEO4~2\apps\Python37\Scripts;C:\OSGEO4~2\apps\Python37;C:\OSGEO4~2\apps\Python37\Scripts;C:\OSGEO4~2\apps\qt5\bin;C:\OSGEO4~2\bin;C:\Windows\system32;C:\Windows;C:\Windows\system32\WBem;C:\Program
 Files\RStudio\bin
 The only way to get QGIS to start was to remove ";C:\Program
 Files\RStudio\bin" from the end of the PATH variable string in qgis-
 bin-g7.env (or to move/rename the folder bin in "C:\Program
 Files\RStudio\")
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/641#comment:16>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
