[Osgeo4w-trac] [osgeo4w] #657: GRASS 7 plugin not working: 3.10.13-2, 3.16.2-2 standalone installers and OSGeo4W network installer
OSGeo4W trac_osgeo4w at osgeo.org
Tue Jan 12 23:00:43 PST 2021
Reporter:  andreaerdna  |      Owner:  osgeo4w-dev@…
    Type:  defect       |     Status:  new
Priority:  critical     |  Component:  Package
 Version:               |   Keywords:
 Using QGIS installed via 3.10.13-2, 3.16.2-2 standalone installers or via
 OSGeo4W network installer, is it not possible to use the GRASS7 plugin in
 QGIS.
 The following error is reported in the Log Messages panel:
 WARNING    GRASS init error : Problem in GRASS
 initialization, GRASS provider and plugin will not work : Module built
 against version d8fbd49af but trying to use version 2b6ab2893. You need to
 rebuild GRASS GIS or untangle multiple installations.
 Moreover, a wrong "QGIS Desktop 3.16.2 with GRASS 7.8.4" shortcut is
 created in the Windows Starts menu, instead of a "QGIS Desktop 3.16.2 with
 GRASS 7.8.5".
 So I think the qgis-grass-plugin7-3.16.2 and qgis-ltr-grass-
 plugin7-3.10.13 plugins should be rebuild against GRASS 7.8.5.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/657>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
