[Osgeo4w-trac] [osgeo4w] #688: Fiona - DLL load failed while importing ogrext: The specified module could not be found. [AGAIN]
trac_osgeo4w at osgeo.org
Sat Jul 24 01:10:23 PDT 2021
Reporter: ondrejsv | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Keywords:
Importing the ''fiona'' package in the new clean OSGeo4W environment
results in the error
''ImportError: DLL load failed while importing ogrext: The specified
module could not be found.''
This directly causes inability to use any other Python package that
depends on the fiona, like geopackage.
Simple reproduction steps on the clean install of the latest OSGeo4W 2
with python3-fiona 1.8.17-3:
C:\app\OSGeo4W_2>python
Python 3.9.5 (tags/v3.9.5:0a7dcbd, May 3 2021, 17:27:52) [MSC v.1928 64
bit (AMD64)] on win32
Type "help", "copyright", "credits" or "license" for more information.
>>> import fiona
File "<stdin>", line 1, in <module>
File "C:\app\OSGEO4~1\apps\Python39\lib\site-
packages\fiona\__init__.py", line 86, in <module>
from fiona.collection import BytesCollection, Collection
packages\fiona\collection.py", line 11, in <module>
from fiona.ogrext import Iterator, ItemsIterator, KeysIterator
ImportError: DLL load failed while importing ogrext: The specified module
could not be found
Note that "workaround" with creating an empty ".lib" directory mentioned
in the #649 does not help. Frankly, if you check the source code file
_loading.py in the fiona, I don't know how it could help.
Also the ".lib" folder is not present by default despite what is said in
the #649 thread.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/688>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
