[Osgeo4w-trac] [osgeo4w] #661: libgrass_gis.7.8 Not Found
OSGeo4W trac_osgeo4w at osgeo.org
Thu Mar 4 04:41:31 PST 2021
Reporter:  PedroNGV             |       Owner:  osgeo4w-dev@…
    Type:  defect               |      Status:  closed
Priority:  major                |   Component:  Package
 Version:                       |  Resolution:  fixed
Keywords:  grass, testing repo  |
Comment (by PedroNGV):
 Hi Helmut
 I've removed curl.exe from system32 now:
 >where curl
 C:\OSGeo4W64\bin\curl.exe
 >curl --version
 curl 7.72.0 (x86_64-pc-win32) libcurl/7.72.0 OpenSSL/1.1.1h zlib/1.2.11
 WinIDN
 Release-Date: 2020-08-19
 Protocols: dict file ftp ftps gopher http https imap imaps ldap ldaps pop3
 pop3s rtsp smb smbs smtp smtps telnet tftp
 Features: AsynchDNS HTTPS-proxy IDN IPv6 Kerberos Largefile NTLM SPNEGO
 SSL SSPI UnixSockets libz
 But keep with the same error.
 I've searched for dependency library issues with dependency walker, the
 output is attached. Can you take a look and see if it's something missing?
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/661#comment:19>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
