[Osgeo4w-trac] [osgeo4w] #677: [OSGeo4W-NG installer] Panda Adaptive Defense 360 block .dlls and .exe
trac_osgeo4w at osgeo.org
Wed Mar 31 01:51:02 PDT 2021
Reporter: jonnyforest | Owner: osgeo4w-dev@…
Type: enhancement | Status: new
Priority: minor | Component: Installer
Version: | Resolution:
Keywords: |
Comment (by jonnyforest):
The easy way is to put all folder recursively in the whitelist Panda
directories but it's against the IT policies.
My hope, for now, is the Panda support grab the information and put in
their whitelist databases.
I send an email explaining the project, the type of installers and point
them to the link of Github project.
So I did a quick search and a Windows forum suggest the following:
[https://social.msdn.microsoft.com/Forums/Windows/en-US/79870753-035e-
438e-ad58-21aa9fa55088/how-to-preventavoid-my-application-from-anti-virus-
software-without-giving-an-exception?forum=windowssecurity]
''I have been working with security for some years now, and none of my
applications have been blocked by Kaspersky AV (either the others). In
order, to prevent this blocking, you should open Visual Studio® and open
your project, then from Project menu select “Properties” and you will come
to the properties page.''
''Now click “Security” tab and check the “Enable Click Once Security
Settings” also provide information inside the assembly info dialog.''
''If the AVs keep on blocking your application now, then navigate to their
application list and modify the AV settings for your application.''
''Also what you can do is, to make a code that checks AV and then adds
it’s self to the application trusted list.''
Does this make sense?
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/677#comment:4>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
